Bitcoin Node Standalone or Multi-tasker?
Should a Bitcoin Node be run standalone or can NextCloud and others Apps be installed on the same Umbrel Home Server?
Yes, it is absolutely possible! :sunglasses:
Umbrel is specifically designed to integrate and efficiently manage multiple services on a single platform.
Thanks to containerization, Umbrel isolates the apps from each other, allowing them to run independently without interference.
