Bitcoin node stack at startup
Hi, Umbrel 1.3 works without a problem. Even before the update, during the synchronization of the bitcoin node, the node crashed on the last percent. The application starts but everything is gray, blocks do not jump in. Everything hangs. Logs show such errors:
Tunnels: Can’t create inbound tunnel, no peers available
Unable to obtain peer info
With the LN application, it is similar, but it is stuck at startup. Restarting etc. does not help. Logs show such error:
[ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
Can someone help me fix this?
Thanks.
