My node is working but the software of the bitcoin core Node stopped unexpectedly. When I view the logs of SW made I get a red line which I attached. I haven’t taken any action untill I reviewed this with you guys.
did you sync the chain already?
if so unfortunately you may have to di it again.
Might want to wait for a second opinon. You will need to reindex which pretty much means it has to do the entire thing again
Yeah I think you will have to re-index. To do that, you go to the apps Settings > Advanced > “Custom bitcoin.conf overrides” > add “reindex=1” > Save Overrides.
This should start reindexing it which will hopefully fix the issue.
Thanks for your answer. Will follow up on your advice.
Also thanks for your answer and explanation. Willfollow up on that. Cheers
No problem. If you do my wolutipn just keep in mind that after you have synced your node to remove that option as it will attempt to reindex on any kind of restart (app or umbrel). Hope it works for you!
