Please Help! BTC & Lightning Node Stuck
My BTC and LIghtning Node will not move past starting!!! I have rebooted and still nothing. Lgos are attached.
umbrel_bitcoin_2024-07-23_07-31.log (173.5 KB)
I’m not all that familiar with the bitcoin-app logs, but I’m not seeing anything that indicates that bitcoind is not running as intended. Can you try connecting via RPC using bitcoin-cli?
This isn’t ideal, but it will tell us if bitcoind is operating properly, and maybe get some traction on this issue.
sudo umbrel/bin/bitcoin-cli/bitcoin-cli -rpcuser=<rpc user> -rpcpassword=<rpc-password> getnetworkinfo
I think that command should work, because according to your logs, the default rpc port is open, and localhost is allowed.
I receive the error no such file.
Thats probably because I put bitcoin-cli twice from the looks of it. Sorry about that!
sudo umbrel/bin/bitcoin-cli -rpcuser=<rpc user> -rpcpassword=<rpc-password> getnetworkinfo
No problem, Im still getting No such file or directory.
What umbrel os version are you on? I am on the latest 1.2.2. It gives a deprecation warning but maybe it’s because I’m using an x86 VM image.
What do you see when you run ls -lah umbrel/bin?
Chiptuner, thank you for the help. I get the command not found. Running 1.2.2 However, I found an error that says the index needed to be reindexed so I went down that road. It is starting now. Thank you so much for your willingness to help.
Well it was at least some place to start. Not a problem. Good catch, I completely missed it!
Error: txindex: best block of the index not found. Please rebuild the index.
Edit:
I feel really silly now. I looked right at it when you first uploaded your logs, it just didn’t register.
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Opening LevelDB in /data/.bitcoin/indexes/txindex
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Opened LevelDB successfully
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Using obfuscation key for /data/.bitcoin/indexes/txindex: 0000000000000000
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Opening LevelDB in /data/.bitcoin/indexes/blockfilter/basic/db
bitcoin_bitcoind_1  | Error: txindex: best block of the index not found. Please rebuild the index.
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Using obfuscation key for /data/.bitcoin/indexes/blockfilter/basic/db: 0000000000000000
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Error: txindex: best block of the index not found. Please rebuild the index.
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Shutdown: In progress...
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z scheduler thread exit
bitcoin_bitcoind_1  | 2024-07-23T11:29:17Z Flushed fee estimates to fee_estimates.dat.
bitcoin_bitcoind_1  | 2024-07-23T11:29:18Z Shutdown: done
