Node Stuck on Starting For weeks now
Hi, i updated umbrel to 1.0 some weeks ago, and since then my bitcoin node got stuck on starting. I tried every solution here on the community and none worked, i will appreciate any help.
My Logs says this:
bitcoin_server_1       | umbrel-middleware
bitcoin_server_1       | Unable to obtain blockchain info
bitcoin_server_1       | /v1/bitcoind/widgets/stats
bitcoin_server_1       | BitcoindError: Unable to obtain blockchain info
bitcoin_server_1       |     at /app/services/bitcoind.js:23:18
bitcoin_server_1       |     at IncomingMessage.<anonymous> (/app/node_modules/bitcoind-rpc/lib/index.js:107:7)
bitcoin_server_1       |     at IncomingMessage.emit (events.js:326:22)
bitcoin_server_1       |     at endReadableNT (_stream_readable.js:1241:12)
bitcoin_server_1       |     at /app/node_modules/async-listener/glue.js:188:31
bitcoin_server_1       |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
bitcoin_server_1       | ::ffff:10.21.0.1 - - [Mon, 06 May 2024 23:43:35 GMT] "GET /v1/bitcoind/widgets/stats HTTP/1.1" 500 34 "-" "node-fetch"
bitcoin_server_1       |
