Backup power - inline USB-C or pi Hat?
Some time ago I had a power out that nuked my entire setup - it took 2-3 days for me to rebuild the blockchain, and by then all my channels were force-closed. Bummer - my fault for not having a UPS.
I’m reluctant to get an APC type device as I’ve had bad luck with their batteries dying way before their expected time.
Are there any decently available - I’ll call it “in-line” usb battery packs that are USB-c ‘in’ and USB-c ‘out’ with enough amps to keep a Pi 8gb +ssd running for 10-15 mins during a power-out situation? and if not that, how about one of these sort of ‘hats’ ?
https://www.amazon.ca/Geekworm-Raspberry-X706-Function-Compatible/dp/B096FT6THL/ref=sr_1_9?dchild=1&keywords=raspberry+pi+4+backup+power&qid=1628519859&sr=8-9
Advice welcome. I’d rather sort this out before opening channels again as my channel-history now looks like a rollercoaster :smiley:
I’m actively looking for an inline power backup setup. I can find power banks with plenty of capacity and max power in excess of the 5v @ 3A needed for my RPi4, but I cannot tell if the battery can deliver uninterrupted power. I tried one and found out the hard way that it didn’t.
Any updates on your end?
Sorry for the slow reply time.
I didn’t find anything that specifically kept passing on power, so I went with a small-format UPS. Not my first choice, but it works.
I used a “Pisugar2 Plus UPS, 5000mAh”, which seems to work really well! However, I think it made the Pi hot and throttle a bit. May be worth putting a fan on it.
