Argon ONE V3 NVME case - SSD not recognized
Hello, I have a issue with Umbrel not recognizing my SSD. I’m using the Argon One 3 NVMe case for RPi 5. I use 2TB Kingston KC3000 which should be compatible. Can someone guide me through the setup? I might have missed something.
The SSD is not connected via USB, it is connected via some kind of PCIe strip provided with the Argon case.
Won’t work at this point. If you search or look at other postings on the site you’ll find lots of conversations about this. Specifically, NVMe isn’t stable or supported, and booting from NVMe and running Umbrel doesn’t work.
