Apps "not running"
I have the following issue with Umbrel 1.1.2 after it worked smooth for some time on a mini-pc.
In the logs, the following appears:
Failed to get memory usage for app bitcoin: Command failed with exit code 1: docker stats --no-stream --format {“container”:“{{.Name}}”,“CPUPerc”:“{{.CPUPerc}}”,“MemPerc”:“{{.MemPerc}}”} bitcoin_app_proxy_1 bitcoin_server_1 bitcoin_bitcoind_1 bitcoin_tor_1 bitcoin_i2pd_daemon_1
Jun 03 09:10:12 umbrel umbreld[654]: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
This error also appears for the other apps.
I think this error appeared after a restart after a failed uninstallation of the thunderhub app.
Can someone help?
I hope we get some answers to this. I tried installing Affine, but it just says “Not running” in the home screen and app store, even after restarting. All of my other apps are fine.
This wouldn’t be too much of an issue, except the monitor says it is currently using CPU. Right-clicking it does nothing but show the same context menu as right-clicking the background.
