Add(connect) node to Umbrel
Hi.
I’ve tried adding by .onion:8332 umbrel Bitcoin node to my laptop node over tor. It connects briefly with zero info then disconnects.
I’m trying to setup Sybil resistance between 3 nodes one with opennet and i2p the other with i2p and tor(for sending transactions).
Any suggestions?
I’ll try this but was trying from laptop first…
Tried.
Says no such container: bitcoin
Connected again using local IP.
It times out and retries often.
Damn.
I’m not synced.
Must be reason I’m not staying connected.
Was hoping to sync from own other node though…
