Add Ckpool on Umbrel Home
Hi , any plans to add ckpool on Umbrel Home ?
I guess it will be great to do that .
Thanks & regards
Isn’t Bassin what you are looking for in the Umbrel App Store?
/app-store/bassin
Bassin
Solo Bitcoin Mining Pool (ckPool)
duckaxe
About
A zero-fee Bitcoin solo mining pool for Umbrel. Run your own ckPool at home.
No setup, no hassle.
Sorry im new actually here i just ordered my Umbrel.
Bassin ? Is this mining pool correct?
And base on ckpool open source?
So, you don’t have UmbrelOS running yet? Do you already have experience running Docker Containers, Github and working with Unix Commands?
While you are waiting for your Umbrel Home Device to arrive, do you have a computer you could install VMware on and start getting used to UmbrelOS in a separate environment?
As for Bassin … GitHub - duckaxe/bassin: Bitcoin solo mining pool for Umbrel
Still i didn’t receive my Umbrel device, also i have a little experience , any yep i have PC & VM or o test on it .
