Use CKpool + Umbrel Bitcoin full node
Hello,
i want to try mining using ckpool and set up my bitcoin full node with umbrel.
but when i’m lauching the “test” CKpool show up some error :
Select timed out in read_socket_line with errno 11: Resource temporarily unavailable
HTTP response to ( "getblock…) 0.251s not ok: HTTP/1.1 401 Unauthorized
localhost:8332 Failed to get valid json response to getblocktemplate
CRITICAL: No bitcoinds active!
does any one tried that before since i dont want to use public-pool
yes, ive seen this error, it happens when I start my pool and its hooked up to the net and not a miner. have your miner going and if everything is right it should connect.
this local host was testnet
I just turned this on with no ethernet and it gave me that error… if I connect it it will start running up the screen…
