System: Rasspbery Pi 5, latest UmbrelOS, Boot from MicroSD card with internal M.2 ssd drive. It worked fine. My ~/umbrel is mapped to the ssd drive.
I want to add a 512gb usb flash so I can do backup. I followed “unofficail giuld to add storage” doc and added an entry into /etc/fstab. I executed CL to mount and I can see the usb drive is mounted correctly.
After re-boot, I am able to ssh to the system with existing password and I can see driver is auto mounted.
However, on the web interface UI, system thinks it is a new set up with message "Welcome to umbrelOS
Your home cloud server is ready to set up."
How to tell the sytem(Web UI) to use the existing set up (MicroSD + M.2 ssd) instead of asking to set up a new system?
