Account Factory Reset
Hello, I just created my Umbrel Home Account, created my desired password with an App I use to store my passwords. It created a strong password that I dont remember and it didnt save it.
So im not able to login without that password. I know, so stupid…
What can I do to reset and create another account? Thanks for the help.
Hey there! Don’t worry; it happens!
To reset your Umbrel password, you can follow these steps from the FAQ: Frequently Asked Questions (FAQs) (How to reset everything on Umbrel except the blockchain? (Eg. if you lost your password))
Let me know if it worked.
Hi Denny. Not working.
There’s any way I could factory reset and create another account? I have nothing in that account.
I would then try to reset. I have already described the process here:
Good evening denny.
I’m completely ignorant about computer science.
“curl -L https://link.umbrel.com/factory-reset | bash” command can be used in windows or only in linux in order to reset Umbrel Home?
If it can´t, how can I reset my Umbrel Home in Windows?
Good evening @pleyar ! :blush:
Since UmbrelOS 1.3, there’s a built-in Factory Reset option. No need to run any commands.
Just open the Umbrel web interface and go to:
Settings → Advanced Settings → Factory Reset
It works from any device, no terminal needed.
