Accessing Node After Power Outage
I ran into this issue after a storm knocked out our power and this is how I resolved it.
I thought this would be helpful in case someone else has this particular issue since it wasn’t already documented.
What I experienced:
  • The Umbrel UI shows up via browser but there is no option to log in or log out.
  • The Shutdown, Restart, and Troubleshoot buttons throw a connection error.
  • I am able to SSH into the Raspberry Pi 4.
How I resolved it:
SSH into Raspberry Pi 4 and reboot using the following command
ssh -t umbrel@umbrel.local
sudo reboot
Good luck!
Thanks! I was finally able to ssh into my umbrel using that command and did the reboot.
However… I have another problem now. When I go to umbrel.local I get a page that says the umbrel refuses to connect … and if I go to the IP address that I assigned to it in my router I get the umbrel start page that never loads. I figured it was offline, but now that I was able to ssh into the umbrel I’m able to ping out :thinking:
That could be a browser caching issue.
Try clearing out your cookies and open an incognito window.
If clearing the browser cache doesn’t work you might want to stop then restart the startup service
