UMBREL doesn't detect new version
Hi, my UMBREL is at version 0.3.10-build-1576e2f. When I CHECK FOR UPDATE, it doesn’t find an update.
Is there a command line procedure?
Thanks,
Hans
I was able to manually reinstall 0.4.1 following the instructions on this post: My node broke while updating to v0.3.13
Good luck!
Yes that worked! After executing the command: cd ~/umbrel && sudo ./scripts/update/update --repo getumbrel/umbrel#v0.3.13
Umbrel found the update and updated correctly.
Many thanks!
H.
