Update OS Version
Hi Umbrel communauty,
I just try a troubleshoot (I’ve no problem with my Node), and I saw that my version 3.1 is different from my OS Version.
0.3.10
Umbrel OS version
v0.3.7-patch-1
Raspberry Pi Model
Revision	: c03111
Serial		: 100000000ec3f86d
Model		: Raspberry Pi 4 Model B Rev 1.1
Is there any problem or should I update ? (And How ?)
Thank you for your help.
To me those version numbers seem to refer to different things. 0.3.10 is your umbrel software version (i have the same on mine, RPI4 too). 0.3.7-patch-1 is the OS version (which is its own thing since you can have the software without using the umbrel OS). If both are up to date there is nothing to do.
I’m a noob though so if anyone could confirm that would be great
Thank you Aaron (and Loadmi) for your answers
