Doesn't show 0.4.2 as available
My Umbrel is running 0.4.1 and when I check for updates under the Settings page, it continues to return “Your Umbrel is on the latest version”. How do I get the 0.4.2 update?
I tried rebooting, no difference. Any advice would be appreciated.
we are already at 0.4.4 so please update to the last one
When I check for updates under the Settings page, it continues to return “Your Umbrel is on the latest version”. Which is obviously not correct.
Just do this:
  • shut down your node
  • take out the mSD card
  • reflash it with the latest umbrel OS
  • put it back
  • start your node
    Done
