Due to issues I installed pi-hole as follows
- Stop Umbrel:
sudo scripts/stop - Reboot your system:
sudo reboot - Start Umbrel:
sudo scripts/start - Uninstall Pi-hole:
sudo scripts/app uninstall pi-hole - Install Pi-hole:
sudo scripts/app install pi-hole
It works now, but I didn’t receive a password so I can’t login. How can I set or extract a password?
