Default passwd for pihole
Hi there,
is there anyway to change the default password for pihole app under umbrel? Nothing seems to work and i cant figure out what account is used to login. I just dont like moneyprintergobrrr.
i tried
“sudo pihole -a -p”
“sudo passwd admin” “pi” “pihole” “root”
nothing seems to have any effect…
kind regards,
Marco
For what its worth: I changed the docker.compose.yml file and set the ```
WEBPASSWORD: [mypassword]
It still didn’t work, but after reinstall pi-hole and installing pi-hole again, the password suddenly changed to [mypassword]
