I run Umbrel on a Raspberry Pi 4 8go connected via Ethernet, with a SSD.
The Bitcoin docker container keeps restarting, it can’t find the settings.json file.
Here are some of the logs:
bitcoin Restarting (1) 22 seconds ago
Bitcoin Core logs
Attaching to bitcoin
bitcoin | Error: Failed loading settings file:
bitcoin | - Unable to parse settings file /data/.bitcoin/settings.json
bitcoin |
btc-rpc-explorer
web_1 | 2021-07-24T16:16:00.417Z btcexp:error Error 937gf47dsyde: Error: connect ECONNREFUSED 10.21.21.10:50001, json: {“errno”:“ECONNREFUSED”,“code”:“ECONNREFUSED”,“syscall”:“connect”,“address”:“10.21.21.10”,“port”:50001}, userData: [object Object] (json: {“host”:“10.21.21.10”,“port”:50001,“protocol”:“tcp”})
Any help appreciated.
Thanks!
Any luck in resolving this issue? I am having the same problem with
Okay, i fixed the issue…
my umbrel/bitcoin/settings.json file was empty and I simply modified it to be
All is well now
Thank you exabyte!
Can you share how to do modify the file please?
Thanks again.
Ok I did:
cd /umbrel/bitcoin and nano settings.json
And it worked! Thanks
BdC
December 11, 2021, 11:29pm
6
…thx, looks promising- but for some reason I can’t log in on the terminal to get started either.
Did you ever get logged in? I can’t ssh from my Linux Mint machine, but I can from my Linux terminal on my chromebook… I hate being computer illiterate.
nobi
October 27, 2023, 6:19am
8
To find your settings.json for Bitcoin on Umbrel:
cd ~
find . -name "settings.json"
look at the results and you will see the path to something like this:
./umbrel/app-data/bitcoin/data/bitcoin/settings.json
then just do nano ./umbrel/app-data/bitcoin/data/bitcoin/settings.json
and add the
