How to find the <lndconnect REST (Tor)> QR code in Umbrel’s new user interface:
In the main Umbrel home screen, click and open Lightning Wallet
In Lightning Wallet, click the three small dots in the upper-right hand corner followed by clicking “Connect Wallet”
Select the <lndconnect REST (Tor)> QR code if it isn’t already selected. Make sure the “Use Tor” button is enabled in Zeus.
Same, wouldnt scan QR. I then entered the details manually and initially Zeus wouldn’t connect, however after about 5 attempts it connected.
I then decided to connect Zeus to Umbrel with Tailscale using Darthcoin’s guide, basically you just replace the onion address in Host with your Tailscale IP and toggle off ‘Use Tor’. Should make for a faster and more reliable connection.
