Weird Umbrel connection
I’m not sure if you guys even see these, but documenting it here incase it’s an issue with umbrel.
Today for some reason I can connect to my umbrel node over tailscale on safari (iphone), but every other connection seems to be dead e.g. via IP address/umbrel.local on laptop/PC, via tailscale on laptop, via Tor, via LNC/Tor to Zeus.
can’t even ssh into this mf. so strange
here are the logs i got from umbrel on my phone umbrel-1679470525172-debug.log (57.0 KB)
can you restart it and get a fresh log
are you sure your local IP didnt change?
you can type
ip addr
in terminal to check.
you logs shows tailscale and tor not starting and a couple other things
exact same here
