Tried resetting it completely. Nothing. I think my Tor is broken or something after the update.
What do I do dudes?
What do I do dudes?
Yes Tor is ded. I hope Umbrel devs will update the latest 4.7.7 patch.
Meanwhile I would really recommend to all Umbrel users to use Tailscale to connect Zeus to their node.
In the end, why would you need Tor to connect to your own node and manage it? You are not trusting yourself?
Tailscale is the best option to this.
That might be a good idea. I’d do it if I could use one tailscale for this and also for BTCPay to replace my reverse proxy… but I’m not sure how I’d do that. Maybe I will play with it. I’m having tons of issues with BTCPay as it is.
