I find what you’re saying confusing…
Were you really using an rpi2 and the problem was happening on this device?
Is this rpi 4 that you’re now mentioning another device with a new installation?
Well, I’ve superficially reviewed the logs and something caught my attention. I’ll explain it to you with a comparison.
The following is from the log of one of my nodes: RPI 4, 2TB disk… well, like the one you say you have now.
usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
usb 2-1: Product: ASM1153E
usb 2-1: Manufacturer: RSH-319
usb 2-1: SerialNumber: 00000000009E
scsi host0: uas
scsi 0:0:0:0: Direct-Access RSH-319 ASM1153E 0 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes not a multiple of physical block size (4096 bytes)
sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
If you look, it shows me the product name, manufacturer and disk capacity: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB).
Ahora, veamos el tuyo.
New USB device found, idVendor=174e, idProduct=1155, bcdDevice= 1.00
usb 2-2.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
usb 2-2.2: Product: SATA
usb 2-2.2: Manufacturer: Pinas
usb 2-2.2: SerialNumber: 0000000000EC
usb-storage 2-2.2:1.0: USB Mass Storage device detected
scsi host0: usb-storage 2-2.2:1.0
usb 2-2.4: new SuperSpeed USB device number 4 using xhci_hcd
usb 2-2.4: New USB device found, idVendor=1741, idProduct=1156, bcdDevice= 1.00
usb 2-2.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
usb 2-2.4: Product: sata
usb 2-2.4: Manufacturer: Pinas
usb 2-2.4: SerialNumber: 0000000000E1
scsi host1: uas
scsi 1:0:0:0: Direct-Access Pinas sata 0 PQ: 0 ANSI: 6
sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Your log detects 2 disks. Both with the same manufacturer, different serial numbers and only detects the capacity of one of them: 1953525168 512-byte logical blocks: (1.00 TB/932 GiB).
Since you had told me…
I am using a Pi2, 2Tb drive and which logs should I attach, and how much?
Is your disk partitioned?..
To check this, connect via SSH to your rpi and run the command:
df
Then paste the result here, please.
