Hello,
for the past few weeks, access to Vaultwarden via the Edge bitwarden extension (newer version) has stopped working. When will the next update for Umbrel be released?
Regards
Hello,
Regards
It’s not a matter of an update unfortunately, the problem is Umbrel doesn’t serve https by default, this has been discussed for many years, yet never fixed. You can try some workarounds, look for the related topics.
I don’t think so, it’s worked before and it still works with the Firefox extension. I have HTTPS access via the nginx proxy manager.
The extension has been working again since the last update to version 1.36.0. ![]()
