Hi!
I would like to use the Robosats app on Umbrel, but when open it I get the message that the version is older version than that is available.
I think I need to update the Docker image, but I do not know how to do that. Can somebody please give me some guidance? Sorry not very technically minded, but trying to get better.
Cheers
Hi @mushinfx , I can confirm the Umbrel Robosats app is up-to-date with the latest release. When you search for Robosats in the app-store, does it suggest you update?
If not, can you please head to your settings, and generate some troubleshooting logs. You can share them here with https://pastebin.com/
Thank you for replying.
The store does not ask me to update and the store states the version as v0.4.0-alpha.
When I open the app it says this:
Weird, do you mind trying the troubleshooting steps I mentioned above.
Otherwise I think you’ll need to do the following.
SSH (Secure Shell) is a way to access and control a device, such as your Umbrel server running on a Umbrel Home or Raspberry Pi, via the command line. To access Umbrel via SSH, follow these steps:
Open a terminal window on your computer. On macOS, you can open the Terminal app that’s installed by default on every Mac. On Windows, you can open Command Prompt or the PowerShell app.
Type in the following command* and press the Enter key:ssh -t umbrel@umbrel.local*In the command given above, you can replace umbrel.local with the local IP of your Umbrel if you prefer. If you are using PowerShell on Windows 10, you may need to run ssh umbrel@umbrel instead of the command given above.
You will then be prompted to enter your password. This is the same password you use to access your Umbrel through a browser. The default password before you have created an account on your Umbrel is moneyprintergobrrr on Raspberry Pi, and umbrel on Umbrel Home. You will not be able to see your password as you type it into the terminal. Once you have typed in your password, press the Enter key.
This will established an SSH connection to your Umbrel server. You can now begin using the command line interface to perform various actions and troubleshoot issues that require SSH.
sudo ~/umbrel/scripts/repo update
sudo ~/umbrel/scripts/app update robosats
I have never got ssh to work on my umbrel. Despite hours and hours of trying.
I have used umbrel@umbrel.local and using my IP with no luck. I have found no solution.
Logging onto the umbrel PC directly, I get the following after executing sudo ~/umbrel/scripts/repo update:
Processing: https://github.com/getumbrel/umbrel-apps.git
Updating repo: https://github.com/getumbrel/umbrel-apps.git (master)
Updating 85f8a5c..7619f4a
error: Your local changes to the following files would be overwritten by merge:
[README.md](http://readme.md/)
agora/umbrel-app.yml
audiobookshelf/docker-compose.yml
audiobookshelf/umbrel-app.yml
bitcoin/docker-compose.yml
bitcoin/exports.sh
bitcoin/umbrel-app.yml
bitfeed/umbrel-app.yml
bleskomat-server/umbrel-app.yml
bluewallet/umbrel-app.yml
btc-rpc-explorer/docker-compose.yml
btc-rpc-explorer/umbrel-app.yml
btcpay-server/docker-compose.yml
btcpay-server/umbrel-app.yml
calibre-web/docker-compose.yml
calibre-web/umbrel-app.yml
circuitbreaker/docker-compose.yml
circuitbreaker/umbrel-app.yml
code-server/umbrel-app.yml
core-lightning-rtl/umbrel-app.yml
core-lightning/docker-compose.yml
core-lightning/exports.sh
core-lightning/umbrel-app.yml
electrs/docker-compose.yml
electrs/umbrel-app.yml
element/umbrel-app.yml
elements/docker-compose.yml
elements/umbrel-app.yml
esphome/umbrel-app.yml
file-browser/docker-compose.yml
file-browser/umbrel-app.yml
firefly-iii/docker-compose.yml
firefly-iii/umbrel-app.yml
firefox/umbrel-app.yml
ghostfolio/docker-compose.yml
ghostfolio/umbrel-app.yml
gitea/docker-compose.yml
gitea/umbrel-app.yml
heimdall/docker-compose.yml
heimdall/umbrel-app.yml
helipad/umbrel-app.yml
home-assistant/configuration.yaml.template
home-assistant/docker-compose.yml
home-assistant/umbrel-app.yml
immich/docker-compose.yml
immich/exports.sh
immich/umbrel-app.yml
invidious/docker-compose.yml
invidious/umbrel-app.yml
ipfs-podcasting/umbrel-app.yml
itchysats/umbrel-app.yml
jam/umbrel-app.yml
jellyfin/docker-compose.yml
jellyfin/umbrel-app.yml
kollider/umbrel-app.yml
krystal-bull/umbrel-app.yml
libreddit/umbrel-app.yml
libreoffice/umbrel-app.yml
lidarr/umbrel-app.yml
lightning-shell/umbrel-app.yml
lightning-terminal/docker-compose.yml
lightning-terminal/umbrel-app.yml
ln-visualizer/umbrel-app.yml
lnbits/docker-compose.yml
lnbits/umbrel-app.yml
lndboss/docker-compose.yml
lndboss/umbrel-app.yml
lndg/docker-compose.yml
lndg/umbrel-app.yml
lnmarkets/docker-compose.yml
lnmarkets/umbrel-app.yml
lnplus/docker-compose.yml
lnplus/umbrel-app.yml
mempool/docker-compose.yml
mempool/umbrel-app.yml
n8n/docker-compose.yml
n8n/umbrel-app.yml
nextcloud/umbrel-app.yml
nitter/docker-compose.yml
nitter/umbrel-app.yml
node-red-standalone/docker-compose.yml
node-red-standalone/umbrel-app.yml
node-red/umbrel-app.yml
nolooking/umbrel-app.yml
nostr-relay/docker-compose.yml
nostr-relay/umbrel-app.yml
oak-node/docker-compose.yml
oak-node/umbrel-app.yml
passky-client/umbrel-app.yml
passky-server/docker-compose.yml
passky-server/umbrel-app.yml
photoprism/docker-compose.yml
photoprism/umbrel-app.yml
pi-hole/docker-compose.yml
pi-hole/umbrel-app.yml
plex/docker-compose.yml
plex/umbrel-app.yml
prowlarr/umbrel-app.yml
radarr/umbrel-app.yml
remmina/umbrel-app.yml
ride-the-lightning/docker-compose.yml
ride-the-lightning/umbrel-app.yml
robosats/docker-compose.yml
robosats/umbrel-app.yml
rotki/docker-compose.yml
rotki/umbrel-app.yml
samourai-server/umbrel-app.yml
satsale/umbrel-app.yml
simple-torrent/umbrel-app.yml
snapdrop/umbrel-app.yml
snowflake/umbrel-app.yml
sonarr/umbrel-app.yml
sparkkiosk/umbrel-app.yml
specter-desktop/docker-compose.yml
specter-desktop/umbrel-app.yml
sphinx-relay/docker-compose.yml
sphinx-relay/umbrel-app.yml
squeaknode/umbrel-app.yml
squeakroad/umbrel-app.yml
suredbits-wallet/umbrel-app.yml
synapse/umbrel-app.yml
syncthing/docker-compose.yml
syncthing/umbrel-app.yml
tailscale/docker-compose.yml
tailscale/umbrel-app.yml
tallycoin-connect/umbrel-app.yml
thunderhub/docker-compose.yml
thunderhub/umbrel-app.yml
torq/docker-compose.yml
torq/umbrel-app.yml
transmission/docker-compose.yml
transmission/umbrel-app.yml
trilium-notes/docker-compose.yml
trilium-notes/umbrel-app.yml
uptime-kuma/docker-compose.yml
uptime-kuma/umbrel-app.yml
urbit-bitcoin-connector/umbrel-app.yml
urbit/docker-compose.yml
urbit/umbrel-app.yml
usocial/umbrel-app.yml
vaultwarden/docker-compose.
Aborting
On executing sudo ~/umbrel/scripts/app update robosats , I get the following
Processing: robosats
Cloning repo: robosats
fatal: repository 'robosats' does not exist
Error: Repo (robosats) missing umbrel-app-store.yml
Repo: robosats does not exist locally.
We will need to do it through SSH, but that’s ok we’ll get there.
When you open Umbrel on your browser is it the IP address or ‘umbrel.local’ that you use. In any case, the one you’ll want to use when SSHing into your device is the same ie ssh umbrel@<IP_address or umbrel.local>
The other thing to check, if the password moneyprintergobrrr is not working, you can also try the password used when trying to log into your Umbrel from the browser.
Let me know if that helps. Then you can try those scripts again.
Thank you for your patience.
Ok, I access Umbrel on my browser using umbrel.local but this is what I get when use the command line
ssh: connect to host umbrel port 22: Connection refused
I also get the same message when I use the ip address.
I am not using a Rasberry Pi. I am using an old mini pc running ubuntu.
