I started the update to 1.3. on a Rasberry 4 and umbrel completely reinstalled itself on the sd card. In the old version 1.2 I had everything on the connected hard disk. My immich archive with all the pictures is now no longer accessible. What can I do to restore the old status? I was so happy with umbrel without having to enter a terminal code. I am a layman and just want to get my immich pictures back. With the urgent request for help and the warning to update to 1.3.
Solution: after restarting twice, everything is restored and I can access my apps. Overjoyed!!! Thanks to the developers for this great idea for people like me to have their own cloud via a simple web interface - without any technical tricks.
Hey @kchris, glad you got it sorted.
Just an FYI, what happened here is that the Pi did not detect your external darddrive when booting up, so it falls back to using the microSD as a storage device. But after a couple restarts (for whatever reason), the hard-drive was detected. It’s possible that the USB connection is a little finicky, but it could also be an indication that your drive might be starting to fail.
