Hello, it’s been a while since I’ve been on my Umbrel. I’m still on 1.1, and when I try to update to 1.4, I keep getting a ‘Failed to Update’ message. Any help. Thx
What is Umbrel on (mini PC, pi, other), apps installed, how large is the storage (external/internal storage device)?
pi, bitcoin node, 2tb external
I don’t know why it would have a problem, except maybe a thermal problem. I would try a new SD card and image it with 1.4. If someone could verify that all the data is on the external drive than what is needed to pop in a 1.4 SD card?
Wait, could my issue be i’m on a Raspberry Pi 4? Does 1.4 work only on Raspberry Pi 5?
I have a Pi 4 and did the upgrade to 1.4 easily, but I keep mine cool.
Where can i find 1.4 for Raspberry Pi 4?
