Umbrel login problem
Hello
I have just install Umbrel and after restart i get a umbrel login
How do i do to get in to the app on the computer i install it to.
I only have 1 computer so i cant log in from a nother pc.
Thanks
Hey @Micael :wave:
Firstly, welcome to the Umbrel Community! Great to have you here!
umbrelOS is a server operating system that is designed to be installed on a headless device that is then accessed over the network. It’s perfectly normal to see the following message if you connect a display to the computer / device you installed umbrelOS on:
umbrel login:
You can login to the terminal session by using the default username umbrel and default password umbrel (unless you’ve previously changed it in the web UI).
Please note, this is not how you access umbrelOS usually, and you should instead go to http://umbrel.local/ on another device to access the full features of umbrelOS. The terminal is only intended for diagnostic purposes and troubleshooting and not day-to-day usage.
You can find more information on the installation guide Wiki page: Install umbrelOS on x86 Systems · getumbrel/umbrel Wiki · GitHub
Hope this helps! :smiley_cat:
Hello, I have the same issue. I type in the login and password but it just shows umbrellas@umbrel:"$.
That is on my mini pc. On my Mac, I try to go to umbrel local but it doesn’t load. What am I doing wrong?
