I cannot access the UmbrelOS user interface, only the terminal is available for use. I tried rebooting the computer multiple times, but the result is always the same.
It would be very helpful if you could provide as much information as possible about your context.
Type of hardware you use.
How does your umbrella connect to the internet?
Has something happened between the time you were able to access it and now you can’t?
Apps installed?
Version used?
Any detail, no matter how small, will help find a solution to your problem.
Unless I’m wrong, this is how it works. You need only find your local umbrel IP(type “hostname -I” in the terminal after you login) and connect to it through a web browser from another device in your network, for example: umbrel.local might also work as an address.
