Error Logs:
0.5.4
Flashed OS version
v0.4.9
Raspberry Pi Model
Revision : d03114
Serial : 10000000411c55c1
Firmware
Oct 29 2021 10:47:33
Copyright (c) 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=53.0’C
Throttling
throttled=0x0
Mem: 7.8G 184M 6.9G 57M 708M 7.4G
Swap: 4.1G 0B 4.1G
total: 2.4%
system: 2.4%
lightning-terminal: 0%
lightning: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
14262 pts/0 S 0:00 bash ./scripts/memory-monitor
/dev/root 29G 29G 0 100% /
/dev/sda1 916G 610G 261G 71% /home/umbrel/umbrel
Startup service logs
Oct 17 19:28:11 umbrel systemd[1]: Stopped Umbrel Startup Service.
Oct 17 19:28:11 umbrel systemd[1]: Starting Umbrel Startup Service…
Oct 17 19:28:11 umbrel umbrel startup[4650]: /home/umbrel/umbrel/scripts/../scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Oct 17 19:28:11 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Oct 17 19:28:11 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Oct 17 19:28:11 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Oct 17 19:28:22 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Oct 17 19:28:22 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 122.
Oct 17 19:28:22 umbrel systemd[1]: Stopped Umbrel Startup Service.
Oct 17 19:28:22 umbrel systemd[1]: Starting Umbrel Startup Service…
Oct 17 19:28:22 umbrel umbrel startup[4666]: /home/umbrel/umbrel/scripts/../scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Oct 17 19:28:22 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Oct 17 19:28:22 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Oct 17 19:28:22 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Oct 17 19:28:32 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Oct 17 19:28:32 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 123.
Oct 17 19:28:32 umbrel systemd[1]: Stopped Umbrel Startup Service.
Oct 17 19:28:32 umbrel systemd[1]: Starting Umbrel Startup Service…
Oct 17 19:28:32 umbrel umbrel startup[4690]: /home/umbrel/umbrel/scripts/../scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Oct 17 19:28:32 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Oct 17 19:28:32 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Oct 17 19:28:32 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Oct 17 19:28:42 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Oct 17 19:28:42 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 124.
Oct 17 19:28:42 umbrel systemd[1]: Stopped Umbrel Startup Service.
Oct 17 19:28:42 umbrel systemd[1]: Starting Umbrel Startup Service…
Oct 17 19:28:42 umbrel umbrel startup[4705]: /home/umbrel/umbrel/scripts/../scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Oct 17 19:28:42 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Oct 17 19:28:42 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Oct 17 19:28:42 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
Oct 17 19:03:36 umbrel external storage mounter[536]: Running external storage mount script…
Oct 17 19:03:36 umbrel external storage mounter[536]: Found device "JMicron "
Oct 17 19:03:36 umbrel external storage mounter[536]: Blacklisting USB device IDs against UAS driver…
Oct 17 19:03:36 umbrel external storage mounter[536]: Rebinding USB drivers…
Oct 17 19:03:37 umbrel external storage mounter[536]: Checking USB devices are back…
Oct 17 19:03:37 umbrel external storage mounter[536]: Waiting for USB devices…
Oct 17 19:03:38 umbrel external storage mounter[536]: Waiting for USB devices…
Oct 17 19:03:39 umbrel external storage mounter[536]: Waiting for USB devices…
Oct 17 19:03:40 umbrel external storage mounter[536]: Checking if the device is ext4…
Oct 17 19:03:40 umbrel external storage mounter[536]: Yes, it is ext4
Oct 17 19:03:40 umbrel external storage mounter[536]: Checking filesystem for corruption…
Oct 17 19:03:40 umbrel external storage mounter[536]: e2fsck 1.44.5 (15-Dec-2018)
Oct 17 19:03:40 umbrel external storage mounter[536]: umbrel: clean, 528093/61054976 files, 163788842/244190208 blocks
Oct 17 19:03:40 umbrel external storage mounter[536]: Mounting partition…
Oct 17 19:03:40 umbrel external storage mounter[536]: Checking if device contains an Umbrel install…
Oct 17 19:03:40 umbrel external storage mounter[536]: Yes, it contains an Umbrel install
Oct 17 19:03:40 umbrel external storage mounter[536]: Bind mounting external storage over local Umbrel installation…
Oct 17 19:03:40 umbrel external storage mounter[536]: Bind mounting external storage over local Docker data dir…
Oct 17 19:03:40 umbrel external storage mounter[536]: Bind mounting external storage to /swap
Oct 17 19:03:40 umbrel external storage mounter[536]: Bind mounting SD card root at /sd-card…
Oct 17 19:03:40 umbrel external storage mounter[536]: Checking Umbrel root is now on external storage…
Oct 17 19:03:41 umbrel external storage mounter[536]: Checking /var/lib/docker is now on external storage…
Oct 17 19:03:41 umbrel external storage mounter[536]: Checking /swap is now on external storage…
Oct 17 19:03:41 umbrel external storage mounter[536]: Setting up swapfile
Oct 17 19:03:42 umbrel external storage mounter[536]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 17 19:03:42 umbrel external storage mounter[536]: no label, UUID=5a642c31-f67d-49d6-8045-045825c02904
Oct 17 19:03:42 umbrel external storage mounter[536]: Checking SD Card root is bind mounted at /sd-root…
Oct 17 19:03:42 umbrel external storage mounter[536]: Starting external drive mount monitor…
Oct 17 19:03:42 umbrel external storage mounter[536]: Mount script completed successfully!
Oct 17 19:03:42 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Tue 2023-10-17 19:03:31 UTC, end at Tue 2023-10-17 19:28:43 UTC. –
Oct 17 19:03:50 umbrel systemd[1]: Starting External Storage SDcard Updater…
Oct 17 19:03:51 umbrel external storage updater[1051]: Checking if SD card Umbrel is newer than external storage…
Oct 17 19:03:51 umbrel external storage updater[1051]: No, SD version is not newer, exiting.
Oct 17 19:03:51 umbrel systemd[1]: Started External Storage SDcard Updater.
