For some reason my Umbrel node hangs after restarting, just saying “Starting umbrel…”
Running on a RasbPi 4b, 1TB SSD, connect over ethernet.
Here’s the output from the debug command; let me know what else might be useful. I think the SD card has failed… but not sure. Any help would be much appreciated!!
0.3.14
Flashed OS version
v0.3.12
Raspberry Pi Model
Revision : d03114
Serial : 10000000550f4c51
Firmware
May 27 2021 14:02:15
Copyright © 2012 Broadcom
Temperature
temp=38.9’C
Throttling
throttled=0x0
Mem: 7.8G 150M 7.4G 8.0M 251M 7.6G
Swap: 0B 0B 0B
total: 1.9%
system: 1.9%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 29G 2.9G 25G 11% /
Startup service logs
– Logs begin at Wed 2021-07-28 16:53:34 UTC, end at Wed 2021-07-28 18:17:01 UTC. –
Jul 28 16:53:42 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Jul 28 16:53:42 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Jul 28 16:53:39 umbrel systemd[1]: Starting External Storage Mounter…
Jul 28 16:53:39 umbrel external storage mounter[487]: Running external storage mount script…
Jul 28 16:53:39 umbrel external storage mounter[487]: Found device “CT1000MX 500SSD1”
Jul 28 16:53:39 umbrel external storage mounter[487]: Blacklisting USB device IDs against UAS driver…
Jul 28 16:53:39 umbrel external storage mounter[487]: Rebinding USB drivers…
Jul 28 16:53:39 umbrel external storage mounter[487]: Checking USB devices are back…
Jul 28 16:53:39 umbrel external storage mounter[487]: Waiting for USB devices…
Jul 28 16:53:40 umbrel external storage mounter[487]: Waiting for USB devices…
Jul 28 16:53:41 umbrel external storage mounter[487]: Checking if the device is ext4…
Jul 28 16:53:41 umbrel external storage mounter[487]: Yes, it is ext4
Jul 28 16:53:42 umbrel external storage mounter[487]: mount: /mnt/data: can’t read superblock on /dev/sda1.
Jul 28 16:53:42 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=32/n/a
Jul 28 16:53:42 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Jul 28 16:53:42 umbrel systemd[1]: Failed to start External Storage Mounter.
Jul 28 16:53:42 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Jul 28 16:53:42 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Bitcoin Core logs
services.tor.ports contains an invalid type, it should be a number, or an object
LND logs
Tor logs
==== Result ====
Please share the following links and paste it in the Umbrel Telegram group (https://t.me/getumbrel) so we can help you with your problem.
https://umbrel-paste.vercel.app/
