Umbrel stopped working how to reboot?
Well here we go again. Was all working just fine for the last 3-4 days. Then today go to sign in and nope it doesn’t work.
I have tried the ssh, nothing. Can someone give me some idea as to how to reboot Umbrel.
Running Raspberry Pi5. I have spend so much time with Umbrel that I’m at the end of the road with it.
The old version worked fine. This new one is a real pain. I have no confidence in Umbrel whatsoever.
You SSHd in and did sudo reboot?
Yes I have done that and nothing happens it just hangs and goes nowhere. Have tried this multiple times.
yep, same thing here. no end of trouble since OS 1. Then I even bought the Umbrel Home thinking it would solve my issues. Just as bad
I ended up shutting Umbrel down at the Raspberry Pi case. I then redone the Micro SD card with umbrel 1.0.4 and restarted and now it is all working ok…for now.
Here we are again…2 days later after working great and go to sign in…and nothing, try to ssh, and it just hangs.
to sign in to the terminal, type in the username “umbrel”, are you registered in the website UI, if no, type the password “umbrel”, if yes, enter the password you used to register, changed the password? if yes, type in the new password.
Terminal access is only available, on PC and/or Raspberry PI computers that had UmbrelOS installed already*
Same issue here, umbrel not responding have to hard reboot the machine to get it to come back up again. Happens every 2 days or so.
