My Umbrel mempool now shows only about 164k unconfirmed transactions.
While mempool.space shows about 400k unconfirmed transactions.
I am wondering why is the difference and how can I fix it?
Thanks,
It’s noting to worry about. The standard mempool size is limited to 300MB. So your node purges low fee transactions if the mempool is overflowing.
You can change this if you like, but have in mind that this will allocate more RAM on your machine.
Have a look at this:
