User and Password Default
Hello, I would like to know what the default username and password are for accessing the terminal? I just installed Umbrel OS 1.1.1 and came across this screen.
I know I can access via local browser, but I would like to have the credentials, is it possible?
when using the terminal the user is umbrel and the password is your password
login: umbrel
password: umbrel
same problem… clean installation 1.1.2 then once i login over local terminal umbrel/umbrel (ok) and now password not working, my www user not working too…
what the hell ?
Can you elaborate on this solution please?
I have the same issue, not able to log in via SSH anymore with umbrel/umbrel, when before it used to work.
OK…i understand now! :man_facepalming:
after installation, the user is umbrel/umbrel, but after completing the WWW wizard and creating your user (name) and password (via WWW), logging into the terminal is login: “umbrell” and password: “my password that I chose via WWW” but with a different name (not my name, but umbrel). …
:wink::man_shrugging:
