Hi there. My umbrel stopped working a few months ago (web browser just couldn’t see it and bring up dashboard login page). I finally got a microhd cable so can plug in a monitor. All proceeding with ‘OK’ messages and then get to login prompt. If I use “umbrel” for “login” and the password I last used, I get the message “Login incorrect”. Any suggestions on next steps?
Did you find the answer? I’d like to log in as well.
Hey @Umbrelos are you having issues accessing your node via SSH or umbrel.local?
