Umbrel.local only shows vertical Umbrelas, but ip is fine?
umbrel.local just has a page of errors and Umbrelas. I can log in fine with i.p.
Any suggestions? Directory mistakes, maybe?
Thanks so much!
If after you reboot you still get the same error, you can SSH and perform command: sudo reboot
Then reflashing will resolve this you can reference steps to reflash your MicroSD here under How To Install: https://umbrel.com/#start
Steps on How To SSH are also listed here: Official Umbrel Troubleshooting Guide and FAQ
Thank you…reflash worked!
