Can't access local umbrel
Hi, can’t acces my local umbrel , tellig me :
Error: Failed to connect external drive
There was an error connecting your external drive. Please consider using the recommended hardware listed on getumbrel.com.
However I’m able to see the ip on ip scan, tried to paste it, also tried to connect with wifi o cable.
anyone help?
Thank you
Can you describe your hardware and setup?
Are you using an SSD with at least 1TB? The recommended one or other?
Have you had to power down or shutoff? You may need to reflash your micro SD if powered off improperly.
Recommend connecting with a network cable, not WiFi (at least not until fully initialized.)
just reflashed the micro sd and was ok. So, now telling 502 bad gateway, sync was over 60 %…
