Umbrel Home still accessable locally but looses connection to internet
I have a new Umbrel Home unit and really loving the experence but seeing a odd behaviour that after a day or so the unit seems to be unable to connect to the public internet, even thought I can still connect to it locally via:
http://umbrel.local/ & ssh -t umbrel@umbrel.local
umbrel@umbrel > sudo ping 1.1.1.1
ping: connect: Network is unreachable
If I restart it all works again via;
sudo systemctl restart NetworkManager
Before I go and Create a systemd service to auto-restart I was hoping I’m missing something more basic, do I just need to set a static IP on the local network (no other devices are having this issue).
I checked the the DNS and cloudflare seems fine;
cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 1.1.1.1
nameserver 1.0.0.1
All help welcome.
Device: Umbrel Home (2024)
Model number: U130121
OS: umbrelOS 1.1.2
We are aware of a networking issue that may be causing this. Can you please try these steps here and let us know if that helps:
Navigate to Settings (http:umbrel.local/settings) > Advanced Settings > Enable the Beta updates program. You can then close that module and select ‘Check for update’, please then update to umbrelOS 1.2 Beta 1.
Thanks @smolgrrr :pray: for responding so quickly. I’ve followed your advise and now running the Beta. I’ll update this thread in a few days to confirm issue has been resolved but happy to assume this is the fix. :+1:
I think Umbrel server (x86) keeps disconnecting after 2-3 days - #12 by mathieuletyrant is the same issue.
I followed the update advice when I had a similar issue and I’ve been stable for a few days now so it should hopefully work for you @bill
