Umbrel Home 1.1.0 hangs on restart
I am running Umbrel Home version 1.1.0
I hit restart fromUmbrel Settings but now it is hanging and doing nothing.
SSH is still working but when I try to run
sudo ~/umbrel/scripts/stop
I get this error:
[sudo] password for umbrel:
Killing background services
Stopping installed apps…
This script requires “docker-compose” to be installed
I don’t know in which state it is currently.
How can I get my Umbrel Home up and running again.
Please help asap because I have some pending HTLCs on my node.
Thank you.
Meanwhile I tried to reboot my Umbrel Home from Shell via
sudo reboot
but Umbrel still not coming up.
What is wrong with the new Umbrel OS.
I start thinking that it was a big mistake to upgrade.
much more robust architecture? ha ha
Today I noticed the same behaviour. I am running a Raspberry Pi 5 with 8GB.
When I hit “restart” , my Pi5 does not restart. But it is no longer accessible via browser.
I have to switch off the power to make it boot again.
I can confirm that everything worked well before the last update.
But with 1.1.0 there is an issue.
I powered off the system using
sudo poweroff -p
when it was powerd off I removed the power plug and put it in again to power on Umbrel again.
Umrel will still not come up.
I am starting to get really annoyed with this new Umbrel OS 1.1.
I need to bring it online soon before my lightning channels start force closing.
@umbrel support - I need a solution now.
Thanks.
I found the solution here:
I am very happy my Umbrel Home is up and running again.
Conclusion: the new Umbrel OS is by far not as robust and stable than we were told.
Do your homework Umbrel team!
An Umbrel Node is no longer a toy system. Some of us have some funds on it!
