Umbrel correct shutdown procedure (USP)
Hello,
is a “normal” shutdown via SSH graceful enough for shutting down umbrel?
Or does shutdown in the web gui something more (like running the stop script)?
Background: I want to connect umbrel to an USP-Server; which is configured like as follows:
SHUTDOWNCMD "/sbin/shutdown -h +0"
I saw docker included in /etc/rc0.d/
K01docker -> ../init.d/docker
So docker will be part of the shutdown routine.
I guess this is it, isn’t it?
Thanks for help :slight_smile:
Hello,
Are you running on a Raspberry Pi where it was setup by you flashing the SD card, etc? If so, that means you’re running Umbrel OS (debian-based distro) where we use systemd to start and stop Umbrel. Therefore when you shutdown like that it will gracefully shutdown Umbrel, docker, etc.
I hope that helps!
Steve
Sorry, yes it’s a Pi4. I forgot to mention that :sweat_smile:
Thanks!
