Last version 6.2.10 has brought some stability at least on my phone. I haven’t managed to make it freeze, which was pretty easy even on version 6.2.9.
Did you noticed?
Did you noticed?
Question if someone can help. I’m very new at this, but have managed to set up and fund my lightning wallet and fund channels. I set up the BlueWallet integration today, linked Blue Wallet HUB, and added funds to my personal BlueWallet Lightning Wallet via sending BTC from Cash App.
I do now see the funds in my BlueWallet app, but have noticed that the funds were also added to my Bitcoin wallet on the node itself. How does this work? doesnt that mean I can now spend those funds from my node’s bitcoin wallet, and if so, what happens to the duplicate lightning funds in blue wallet?
Confused. sorry if it’s a noob question.
Yeah, it’s bit confused, because lndhub txs are still shown in the general node listing.
In the future it will be (I hope) marked in some different way and not shown / or shown in a different way in the node listing txs.
But don’t worry, those sats are NOT in your regular LN wallet available to spend. Are only using the liquidity of your node, not the balance.
But yes, you need to provide good liquidity with your node in order to be able to offer those “banking services” for lndhub wallets.
Thanks for the answer. Indeed the transfer did show up in the transaction list, but it also increased my Bitcoin balance on Umbrel. Is this a bug?
Note the image here. Before this addition from CashApp to Blue Wallet, I had 35k sats or so in my Umbrel Bitcoin Core Wallet. After the transfer of 61k sats, it shows as a deposit in the Bitcoin core Wallet and balance is increased by that amount.
But man, this is onchain wallet, and have nothing to do with LNDHUB. This is totally different.
Exactly, hence my confusion.
Just so you can see, my blue Wallet lightning balance also increased. At first I thought I had accidentally transferred to my on chain Wallet, but no because it shows here too.
Note that I found someone with I think the same issue, but not sure if that was resolved. Blue Wallet Lightning Node
To add additional context, I used the “Refill with External Wallet” button under “Manage Funds” in the Blue Wallet app and sent from an on-chain custodial wallet (cash app) to produce this issue. Can someone else try this on their instance to verify what is occurring here?
Does that mean that people who get a BW wallet on your node create a channel to your node?
No. Please read again the guide. it is explained there what is happening.
I see, sorry, I had to read it more carefully. So what is happening is that LNDHub is managing the money in the wallets, but that money is not actually used for transactions, instead the liquidity on the node is used.
So in case I want to use Bluewallet with my own Lightning Node, then in order to spend eg 50 ksat, I would have to create a channel with 50ksat on my node + create a lightning wallet on BlueWallet with 50ksat ?
No.
Your node channels / liquidity is like water in some pipeline. The water is transport meaning.
Your funds in a LNDHUB wallet, is linked and depends on that liquidity, your funds are the “ships” carrying value (sats) from your wallets. Your node is only facilitating to you the way of transport.
Without good liquidity, your ships will just wreck in ports (wallets), so it is important that you, as node operator, keep a good flow of water in/out of your node channels.
The user of LNDHUB wallet, do not have to worry about that liquidity or opening channels, is just a user/customer of that liquidity.
So as a node operator, try to keep the total amount of inbound and outbound liquidity at a certain level of balancing. Not channel balancing is important, but total liquidity.
Still a lot of confusion around this topic. I think in your example the gasoline would better apply to your channels liquidity to “send” the car is the channel. The family and friends using your node borrow your car and its gas and they provide the cargo (how much to send and to whom) and their cargo rides in your car using your gas. They cannot see or use your cargo “your balance”.
What has caused me confusion is grasping these items:
Umbrel only has 1 wallet built in and it is an onchain BTC wallet
Connecting BW to your umbrel, all it does is use your node instead of BW node when creating wallets. If you create BTC wallets or vaults it just uses your BTC node to validate. If you use BW to create LN wallets then it does not use any balance on your umbrel but it does use your nodes channels and liquidity to send and receive to your BW lightning wallet. Creating a LN wallet in BW that is connected to your node, that LN wallet is still on your phone, not viewable on the node, just uses the node to route.
I am having this same issue. Did you ever happen to find the reason or solution to why this was happening?
I cross-posted - see the other thread for more detail on where I landed: BlueWallet LNDHub Balance showing in On-Chain BTC Wallet
Is there anyway to see the balance of the different wallets created which uses my node as liquid rail? (Such as possible in the LNDhub app)
maybe I don’t get it so far. But I’m wondering about some possible issues:
This could be a future implementation of LNDhub, not Umbrel related.
People should understand: Umbrel is just an interface that put together each piece of software. Umbrel have little to nothing to do with developing these apps.
You should ask this question in Bluewallet telegram community.
