Umbrel as watchtower
Hi I want to try to make my umbrel an watchtower
I was playing around adding
[watchtower]
watchtower.active=1
to lnd.conf + restarting the node as a first step.
From my understanding after restart I should be able to get into
docker exec -it lnd sh
and than run lncli tower info
Sadly the first command fails with
Error response from daemon: Container XXX is restarting, wait until the container is running
Same happens with
[wtclient]
wtclient.active=1
I also tesed =true but with the same error message in both cases. Any idea?
Missing watchtower path-to-files configuration.
But I guess watchtower server is something to put in public nodes. Or if you have several nodes in your intranet.
Keep your nodes running full time and you don´t need any watchtower.
Here in the troubleshooting manual I put all the instructions how to run your node as WT server and/or client
