Adding watchtower to Umbrel node?
Have you managed to add a watchtower to your Umbrel. Do you have updated instructions on how to do so on Umbrel v0.4.2?
I did it with these steps described in this “Umbrel troubleshooting manual” that I am trying to keep up to date with more stuff.
I just launched a free robust Watchtower in case you want to add one: https://lightningnetwork.plus/watchtower
Great! Keep adding more “how to” guides on that web. You are doing great job! Noobs need it.
video tutorial for noob please :sweat_smile::pray:
You have all the simple steps in Umbrel troubleshooting manual, not necessary a video for that.
I finish this step > save & close the lnd.conf file (CTRL+X)
And i can’t run this step : run docker-compose restart lnd
Sorry i am noob in coding :sweat_smile:
you need to be in the umbrel folder in order to run that command
cd umbrel
or just restart the node from dashboard - settings - restart
or
sudo ./scripts/stop
sudo ./scripts/start
thank you
