Background
Hey guys!
When configuring a watchtower client on my umbrel node, I run into issues with lnd not starting. The last thing the lnd log prints is: unable to create server: tower not found
Previously, I have tried to add some watchtowers through lncli and I’m not sure if something went wrong there. I moved/backed up the lnd/data/watchtower/bitcoin/mainnet/watchtower.db and let it be created on a lnd reboot, so I’m assuming the db should be empty and there is no other location where the active watchtowers are tracked.
I’d appreciate any help a lot, I’m a bit uneasy to run my node without a watchtower.
Your environment
- Umbrel 0.4.2
- On what device / OS you are running Umbrel: Raspberry Pi
- How is your Umbrel connected to the Internet: Ethernet
- What type of drive you are using: SSD
- version of
lnd: v0.13.1-beta
Steps to reproduce
In the lnd.conf, I have activated the watchtower and lnd restarts without any issues.
[watchtower]
watchtower.active=1
When trying to activate the client with
[wtclient]
wtclient.active=1
and restarting lnd (docker-compose restart lnd), I get the following lnd log:
2021-09-16 15:12:28.523 [INF] LTND: Version: 0.13.1-beta commit=v0.13.1-beta, build=production, logging=default, debuglevel=info
2021-09-16 15:12:28.523 [INF] LTND: Active chain: Bitcoin (network=mainnet)
2021-09-16 15:12:28.560 [INF] RPCS: RPC server listening on 0.0.0.0:10009
2021-09-16 15:12:28.562 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
2021-09-16 15:12:28.569 [INF] LTND: Opening the main database, this might take a few minutes...
2021-09-16 15:12:28.569 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
2021-09-16 15:12:29.042 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
2021-09-16 15:12:29.180 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
2021-09-16 15:12:29.563 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
2021-09-16 15:12:30.930 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
2021-09-16 15:12:31.671 [INF] CHDB: Checking for schema update: latest_version=22, db_version=22
2021-09-16 15:12:31.671 [INF] LTND: Database now open (time_to_open=3.101283509s)!
2021-09-16 15:12:31.671 [INF] LTND: Waiting for wallet encryption password. Use `lncli create` to create a wallet, `lncli unlock` to unlock an existing wallet, or `lncli changepassword` to change the password of an existing wallet and unlock it.
2021-09-16 15:12:32.420 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:34.257 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:36.859 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:36.859 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:36.873 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.948 [ERR] RPCS: [/lnrpc.Lightning/WalletBalance]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.948 [ERR] RPCS: [/lnrpc.Lightning/GetTransactions]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.950 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.961 [ERR] RPCS: [/lnrpc.Lightning/ListInvoices]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.962 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:38.963 [ERR] RPCS: [/lnrpc.Lightning/PendingChannels]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:39.056 [ERR] RPCS: [/lnrpc.Lightning/ListPayments]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:39.201 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:39.261 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:41.396 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2021-09-16 15:12:42.078 [INF] LNWL: Opened wallet
2021-09-16 15:12:42.255 [INF] CHRE: Primary chain is set to: bitcoin
2021-09-16 15:12:42.285 [INF] CHRE: Initializing bitcoind backed fee estimator in CONSERVATIVE mode
2021-09-16 15:12:42.285 [INF] LNWL: Started listening for bitcoind transaction notifications via ZMQ on 10.21.21.8:28333
2021-09-16 15:12:42.285 [INF] LNWL: Started listening for bitcoind block notifications via ZMQ on 10.21.21.8:28332
2021-09-16 15:12:42.293 [INF] CHRE: Using external fee estimator https://nodes.lightning.computer/fees/v1/btc-fee-estimates.json: cached=true
2021-09-16 15:12:42.294 [INF] LNWL: Starting web API fee estimator
2021-09-16 15:12:45.218 [INF] LNWL: The wallet has been unlocked without a time limit
2021-09-16 15:12:45.224 [INF] CHRE: LightningWallet opened
2021-09-16 15:12:45.229 [INF] SRVR: Proxying all network traffic via Tor (stream_isolation=false)! NOTE: Ensure the backend node is proxying over Tor as well
2021-09-16 15:12:45.250 [INF] HSWC: Restoring in-memory circuit state from disk
2021-09-16 15:12:45.252 [INF] HSWC: Payment circuits loaded: num_pending=0, num_open=0
2021-09-16 15:12:45.279 [INF] HSWC: Trimming open circuits for chan_id=700215:1561:0, start_htlc_id=1
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697402:2025:1, start_htlc_id=0
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697335:1350:0, start_htlc_id=3
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697360:88:1, start_htlc_id=0
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=699092:1129:0, start_htlc_id=0
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=700787:559:1, start_htlc_id=20
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697341:2104:1, start_htlc_id=19
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=698968:871:1, start_htlc_id=2
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=700096:282:0, start_htlc_id=0
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=698420:2478:1, start_htlc_id=0
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697853:1215:1, start_htlc_id=15
2021-09-16 15:12:45.280 [INF] HSWC: Trimming open circuits for chan_id=697801:2794:1, start_htlc_id=1
2021-09-16 15:12:45.281 [INF] HSWC: Trimming open circuits for chan_id=700809:1666:0, start_htlc_id=0
2021-09-16 15:12:45.281 [INF] HSWC: Trimming open circuits for chan_id=699537:533:0, start_htlc_id=1
2021-09-16 15:12:45.334 [INF] LTND: Channel backup proxy channel notifier starting
2021-09-16 15:12:45.335 [ERR] LTND: unable to create server: tower not found
2021-09-16 15:12:45.336 [INF] LNWL: Stopping web API fee estimator
2021-09-16 15:12:45.360 [INF] LTND: Shutdown complete
Expected behaviour
lnd boots and actually starts a communicating with configured watchtowers
Actual behaviour
lnd crashes and restarts in a loop.
Any ideas why the server cant be created?
