I’m having trouble getting a watchtower client running on my Umbrel’s LND node. Found lots of help in various places online, but most are old and none of them seem to be working for me.
First, here’s the relevant part of my lnd.conf:
umbrel@umbrel:~ $ cat ~/umbrel/app-data/lightning/data/lnd/lnd.conf
[wtclient]
wtclient.active=true
wtclient.sweep-fee-rate=10
Here’s how I’m restarting LND:
umbrel@umbrel:~ $ ~/umbrel/scripts/app compose lightning restart lnd
Restarting lightning_lnd_1 ... done
Then wait a minute and check the wtclient stats:
umbrel@umbrel:~ $ ~/umbrel/scripts/app compose lightning exec lnd lncli wtclient stats
[lncli] rpc error: code = Unknown desc = watchtower client not active
Thanks in advance for any advice or troubleshooting tips.
I think I figured it out on my own, there’s a new “Advanced Settings” menu item in 0.5.4 that has toggles for Watchtower and Watchtower Client, those worked for me so I backed out my changes to lnd.conf and used those options in the UI instead.
Thanks for sharing, I was just about to mention this. Weird that adding it to lnd.conf didn’t work though
I’m running Umbrel 1.3 and don’t see those features. Is there a new place to locate them?
Umbrel 1.3, how to setup a Watchtower.
- Log in Umbrel node.
- Open the Lightning Node app
- Using the three (3) dots in the upper right-hand corner. click>advanced setting
- scroll down to watchtower area and add or make changes as you need.
- go to the bottom select save and restart node.
The field for WT client is grayed out. How to solve this?
There should be a switch or slider to the far right of the Watchtower Client words. Slide/click it to turn it green. Then restart the node. It will take a while for everything to be fully loaded.
