Umbrel API available?
Hey dudes, is there an API integrated in Umbrel to get transaction data out to a PC in the same network for data crunching e.g. making some graphs for transactions and fees over time?
You can use the Mempool’s API by installing the Mempool app first, then go to umbrel.local:3006/api/
or you can use the Mempool app to view the graphs and all that since it’s exactly what you wanted
But mempool app deals only with the blockchain part and not with Lightning transactions or am I wrong?
