Umbrel 4.11 - Specter password/authentication issue
After changing rate limit from 200 ms to 20 ms, I cannot login to specter anymore. I cannot come up with any other reason, why Specter Deskop says “Invalid username or password” when I try to login.
I did not write a new password when making the change. After logout I cannot login anymore.
Been using password authentication before changing rate limit without any problems.
I’m sure I’m using correct credentials.
Anyone experiencing the same problem or have a suggestion that might help?
Thanks!
