Umbrel 0.4.7 is out with LND 0.13.4 and updated apps
Umbrel 0.4.7 is out with LND 0.13.4 and updated apps (BTCPay Server, Specter Desktop, Pi-hole, Lightning Terminal, and more) in the Umbrel App Store. :rocket:
This version of LND fixes a bug discovered in the previous version which will break Neutrino functionality after the Taproot activation in ~3 days. Because Neutrino is used by LND when Bitcoin Core is still syncing on Umbrel, in short:
- If Bitcoin Core on your Umbrel hasn’t finished syncing, please update immediately.
- If Bitcoin Core on your Umbrel is 100% synced already, you remain unaffected by this bug and can update at your convenience.
Twitter announcement: https://twitter.com/getumbrel/status/1458413900706181127
update went smoothly – thanks!
I’m having a problem with the update.
Works like a charm! Good work!
These are my logs:
=============== UPDATE ================
========== Stage: Download ============
Creating lock
Cleaning up any previous mess
Downloading Umbrel v0.4.7
curl: symbol lookup error: /usr/lib/aarch64-linux-gnu/libcrypto.so.1.1: undefined symbol: h2s_ASN1_ENUMERATED_TABLE, version OPENSSL_1_1_0
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Running update install scripts of the new release
/home/umbrel/umbrel/scripts/update/update: line 118: cd: scripts/update: No such file or directory
ls: cannot access ‘*-run.sh’: No such file or directory
Deleting cloned repository
Removing lock
Got signal: update
karen is getting triggered!
Not sure what caused this issue, but after upgrading to 0.4.7 I had to uninstall all of the apps being updated and reinstall them to get them to work again…
