Umbre.local doesn't work in Tor browser
I am trying to run umbrel.local in Tor browser but doesn’t work, What Can I do?
Thanks
If is .local mean is local not on Tor.
Use a normal browser not Tor. Tor browser is ONLY when you access your node from outside of your LAN, when you are not at home!
If I a not on my wifi network, would TOR work? I turned wifi off on my Android and give TOR my onion address but it does not open my node. What am I missing?
Thank you,
Dora The Explorer
